S-10 & Blazer 1982-2005
P0420 code, o2 sensor replaced, service light is back same code
Old Jun 14, 2016 | 6:18 PM
s10 troubles's Avatar
Default P0420 code, o2 sensor replaced, service light is back same code
Hello, I have a 1997 Chevy s10 4.3 vortec (x) 4x4 extended cab. I have a o2 sensor low efficiency code p0420. I replaced with a new o2 sensor and light came back on after resetting, in about 30 miles of drive time. Has anyone had this issue and resolved it? And if so, I would appreciate some feedback on where to go next. I have tried carb cleaner in the carb, and let it soak for a while, no success. I was thinking the cat, but its not losing power. It has 168,000 miles, looks like the cats been on there a while. I put some cleaner in the tank for the injectors etc. And 93 octane gas. No difference. Any help is appreciated, thanks in advance
Old Jun 14, 2016 | 7:54 PM
probably needs a cat. don't buy a cheap one or the low cerium content will cause the p0420 dtc to reset.
Old Jul 17, 2016 | 8:49 PM
eagle98's Avatar
check your fuel pressure, idel and under load...
Old Jul 18, 2016 | 8:09 AM
cleveland63b's Avatar
p0420 and p0430 almost always end up being cats and I wouldn't recommend anything other than OEM, at that mileage I wouldn't be surprised. If you have access to a scantool you may be able to do a test drive watching 02 sensor data
Old Sep 4, 2016 | 12:15 PM
bodatiouskid's Avatar
My #1 O2 sensor code comes up,& my cat has been gutted.Is that why it comes up?Have a friend with a gutted cat but his light doesn't come up.
Old Sep 4, 2016 | 12:24 PM
start a new thread. post the model, year, engine and the code
