S-10 & Blazer 1982-2005
p0442 code on 2004 Chevrolet Avalanche
Old Mar 7, 2017 | 2:49 PM
ahcheuk's Avatar
Default p0442 code on 2004 Chevrolet Avalanche
Just get one code. Would it be just leak from canister Purge solenoid?
Old Mar 7, 2017 | 3:02 PM
kevinkpk's Avatar
Possibly, it might be a vacuum line to, or from it. If the hose(s) are 13 years old, that'd cause it. I have about completely replaced all my vaccum lines on my 96.
Old Mar 7, 2017 | 8:37 PM
p0442 is a small leak dtc. if the purge was not sealing, you could/would have a hard start after fueling. have the system smoke tested.
Did this code just set or is it an old code? most evap monitors don't run in the winter due to temperatures out of the monitor parameters.
