S-10 & Blazer 1982-2005
Possible fuel emergency shut off issue
Old Jul 22, 2012 | 1:46 PM
Daniel Abendroth's Avatar
Unhappy Possible fuel emergency shut off issue
I was leaving my apartment and turned too sharp and run up on the curb. It was a pretty rough bump. It ran for a bit, died, and wouldn't start. I let it sit and it ran for a couple minutes and died again. I let it sit over night, about 10 hours, and wouldn't start.
I was told it might be an emergency fuel shut off. Could that be the issue? If so, how do I fix it?
If not, what could it be?
Thank you.
Old Jul 22, 2012 | 7:00 PM
that's a ford feature...chevy's don't have that.
checking fuel pump operation is a good place to start. cycle the key to the key on position...can you hear the fuel pump run for 2 seconds?
Old Jul 23, 2012 | 8:14 AM
It was a Ford enthusiast that suggested it.
Yes. It runs for 2 seconds then stops. Usually, I think, it would run for longer.
Old Jul 23, 2012 | 4:16 PM
its runs for 2seconds to build system pressure then shuts off if no crankshaft signal is detected.
check for spark
Old Jul 23, 2012 | 10:30 PM
As far as I can tell there is no spark.
Old Jul 26, 2012 | 6:41 AM
I replaced the coil pack, distributor cap and rotar and now it runs fine.
turbodremz
May 5, 2025 1:17 PM
mrwalker534
Nov 13, 2011 8:57 PM
nherweck
Nov 3, 2011 8:36 AM
08silveradonb
Jan 13, 2008 12:24 PM
diane888
Aug 5, 2007 9:46 PM
