S-10 & Blazer 1982-2005
Problem finding the right rear rotors for 2000 S-10
Old Oct 20, 2017 | 4:46 PM
Fnhfive7's Avatar
Newly Registered
Default Problem finding the right rear rotors for 2000 S-10
Hi, I have been searching for a set of rear rotors online for my 2000 S-10 and am having issues. I wanted to convert my S-10 to disc brakes, so I got a rear end from a 2000 Blazer a friend had that had disc brakes on it already. The rotors looked really rough, so I wanted to buy some more. The ones I want to replace are 11.6" wide & they are right at 3 11/16" tall, however, when doing a search for 2000 S-10 Blazer online most all that come up have the same width, but the height is 2 7/8th. I found some that have the same dimensions as mine, but it says they are for a 4wd and I need 2wd. Do you think the rear end I got with the disc brakes is from a 4wd? If it was wouldn't the rear end be wider than my 2wd?? Because they are the same. Any help is greatly appreciated.
Josh
Old Oct 21, 2017 | 9:06 AM
As long as all the dimensions are the same then it will work. Can you turn the old rotors or are they too far gone?
