S-10 & Blazer 1982-2005
Putting in a clutch
Old Feb 12, 2008 | 4:49 AM
BigAl88's Avatar
Default Putting in a clutch
Hi, just joined and looking for some advice. I have a 1989 S-10 Blazer, 4.3L, 4x4, automatic. I was wondering how hard it would be to put a clutch in that. I'm getting ready to overhaul the engine this summer and maybe shift kit the tranny. I've got some lifters sticking when i first start it up and maybe a rod knock so its getting tore down. I was just wondering if i could put a clutch in while i had everything out, or is it even worth it? Thanks in advance.
Old Feb 12, 2008 | 8:05 PM
shawnvw's Avatar
Banned
Default RE: Putting in a clutch
worth every penny. If you are going through the labour of removing the engine, it will take all of about 45mins to replace the clutch. If you get a rebuilt, not only are they fairly cheap, but most come with the tool needed to center the clutch when you bolt the pressure plate back on.
Old Mar 8, 2008 | 4:10 AM
2tallcustomz's Avatar
is an auto or manual? if it is auto there is no clutch. are you wanting to go from auto to manual?
Old Mar 10, 2008 | 1:58 AM
BigAl88's Avatar
It has the 700-R4 in it and i'd like to convert it to manual.
Old Mar 10, 2008 | 3:34 PM
ok. you can pick a decent 5 speed almost anywhere. as far a putting in the clutch setup the easiest way to do it and cheapest would be to go to a salvage yard and pick up all the parts you need as far as clutch pedal, linkage, and resvoir and slave cylinder go. the problem comes in that most 5 speeds or manual trans around those years where a hydrualic setup. you will have to run hydrualic lines and drill a hole in the firewall to run the plunger for the resevoir.cable type set up were a little more rare to find but if you can find one it would be much easier to setup. you will also have to get a flywheel and new clutch and pressure plate. i would save time and money in the long run by buying a new flywheel, clutch, and pressure plate.
pdrayton
10
May 5, 2024 2:27 PM
danifid
Nov 17, 2007 4:17 PM
Toby T
Mar 10, 2007 5:48 AM
Travis G
Nov 30, 2006 1:45 AM
antmesa
Aug 28, 2006 3:35 PM
