Question on an engine swap
Hey everybody, I wanna swap out my 2.2L for a Vortec 4.3L V6. Will the computer recongize this engine or will i need to replace the whole computer system. Also, will i need to get a new transmission if i put the Vortec in? If this wont work I appreciate any other engine ideas for my truck. I want something with a little more power but i dont want it to be a huge gas hog. Thanks for all the help.
if your going to replace the engine in your truck i would get a doner truck with the 4.3 in it cuse you will need all the wiring tranny and i think the motor mounts as well as the tranny i think and also the rad from the donur truck as well. if you get a truck with all that stuff in it it should make the swap cheaper.
You are right.
It is cheapest to change engine size if you find a cheap pickup. You will have everytihng you need in that pickup.
What year is your pickup? You said you want a vortec. I will assume that your's has a throttle body.
Your best bet would be to get a donor.
You may have to geta drive shaft made I dobut it though.
good luck
good luck
Just curious, it seems like for the cost of a vortec and/or doner truck. you could probably pickup a decent (newer model) 90's + with it already in.
my 94 s10 4X4 4.3 is only max worth like $5k if I remember KBB? you could probably picksomething up in the auto trader for a few k. you may have your own reasons for upgrading so just a suggestion
Anytime you start to tear down something to change it you will end up spending money.
However I would agree with dragonrpc if you just want something to drive around town or pull something small you would be better off just getting a completely new pickup.
That is a lot of stuff to change and if you don't get it off a donor truck you will have to scavange it or buy it new. Either way it will not be very cheap.
