S-10 & Blazer 1982-2005
Releasing Tension on Idler Pulley
Old Jun 21, 2011 | 11:30 AM
j5403h's Avatar
Default Releasing Tension on Idler Pulley
I am trying to change my aternator and can't seem to figure out how to release tension on belt idler pulley. i have the bolt loosened but don't quite know how to release tension. I'm reasonably sure it is not too complicated but don't want to break anything prying too hard.
Appreciate any help.
Old Jun 21, 2011 | 5:13 PM
old dog's Avatar
what year and engine ,s-10 or blazer ? usually there is a a Square hole in the idler pulley bracket to put the 1/2 hex of a breaker bar in to pull back enough to releaase tension on the spring in the idler and remove the belt .
Old Jun 24, 2011 | 10:23 AM
uneasy_rider's Avatar
Yeah, there is either a square plug for a breaker bar/ratchet or a bolt through the pulley that you can just pull it out of the way with a wrench to take the belt off. It is spring tensioned, so you can't take the tension off, but rather lessen the tension and remove the belt.
ihman
Jun 7, 2015 11:04 AM
Sebastian Saldana
Jan 10, 2014 2:23 PM
maxxman04
Mar 9, 2010 5:34 PM
kashmoney
Jun 23, 2008 6:45 PM
freight shaker
Jan 5, 2008 3:41 PM
