S-10 & Blazer 1982-2005
Replacement for GM part 15149281 Heater Outlet Hose
Old Jul 3, 2017 | 1:44 PM
xxallen's Avatar
Default Replacement for GM part 15149281 Heater Outlet Hose
GM Part 15149281 Heater Outlet Hose has been discontinued. I can't find a replacement anywhere. The metal pipe section of this part number has a small hole and is blasting a steam-like cloud of coolant right at the oil check/fill. Is there an aftermarket hose that can be used to replace this? Perhaps one single piece of heater hose that removes the metal tube?
Old Jul 4, 2017 | 12:43 AM
Rednucleus's Avatar
maybe cut the failed section out and replace it with standard heater hose/clamps. Careful not to collapse the tube with the clamps.
Old Jul 4, 2017 | 9:46 AM
This place says they have it. It is worth checking it out. You should also be able to improvise something to take it's place.
Buy GM 15149281 Hose, genuine OEM part
