S-10 & Blazer 1982-2005
Replacing plugs, cap, rotor, and wires
Old Jul 19, 2007 | 5:07 PM
gearhead_12's Avatar
Default Replacing plugs, cap, rotor, and wires
Ok, so I drive a '92 S10 truck. it has a 2.8 v-6 in it and i've had it for about 5 years. It had been running kind of crappy and my friend showed me a way to check the computer without having to take it into the shop. You stick a wire in the terminal plug-in right underneath the steering collumn and the "check engine soon" light will blink. depending on how fast and how many times that light blinks you will get a number. my came out to be 43, you check this number on the internet and it said that i had a problem with my sparkplugs, cap, rotor, and/or wires. well it had been awhile since any of those had been changed so i decided to replace everything.
I got the right stuff and did it myself, i must say getting the old wires out was a pain in the ****. So i finally got everything replaced, and i know for sure that i got the right order on the cap, but it still runs like it did before, and i keep getting the same number when i run the test. my friend thinks it is because i didn't get the wires back to their original position. Any help?
Old Jul 30, 2007 | 2:49 PM
chevy girl13's Avatar
Default RE: Replacing plugs, cap, rotor, and wires
I does not matter if you change the problems that it is giving you. You have to reset the computer. It is a pain, you can not listen to the computer they will give you errors if the gas cap is not on write.
Old Sep 19, 2007 | 7:47 PM
sickvortech1's Avatar
hello gearhead, i would suggest a FREE scan with a obd2 scanner from autozone-pepboys-advance-
etc, just tell them your sevice ligh is on, obd2 gives a very accurate reading and some advance stores can give you a printout of the coads. the haynes manual gives you a listing of what the coads are a majority of time, i'v seen a few rare casses of unfound coads. a crappy running engine could be many
things -bad o2 sensor-clogged or dirty fuel filter- map sensor-fuel pressure regulator and so on,
i would also suggest the haynes manual,very helpful for DIYers.
Old Sep 20, 2007 | 6:58 AM
golfer's Avatar
1992 vehichles don't have OBD2 ... they have OBD1 ... completely different.
Old Sep 22, 2007 | 11:10 AM
yep, my oversight thay are different...obd1... not... obd2... as long as you get the free scan.
good luck with the truck.
rowekmr
Jan 7, 2020 6:14 PM
scice
Jan 15, 2015 9:25 AM
93ChevyVan
Dec 20, 2013 8:58 AM
Mauber90
Feb 2, 2013 11:19 AM
shamrock246
Apr 10, 2011 7:51 AM
