rocker arm nut help needed
hello im in the process of puting back togather a 1998 gmc jimmy 4.3 vortec.the problem im haveing is with the rocker arm nuts here is the problem im haveing im torqueing the nuts to the 20ft lbs as per a hans manual the qustion i have is ther are 2 rocker arms that the nut is bearly on the stud and with all the outher rocker arms there is threed showing through the nuts help plz
