S-10 & Blazer 1982-2005
S-series DTCs explained
Old Apr 18, 2008 | 5:50 PM
  #11
EvansBlue's Avatar
Default RE: S-series DTCs explained
P0440
Schematic
CIRCUIT DESCRIPTION
The evaporative system includes the following components:
* The fuel tank
* The EVAP vent solenoid
* The fuel tank pressure sensor
* The fuel pipes and hoses The vapor lines
* The fuel cap
* The evaporative emission canister
* The purge lines
* The EVAP purge solenoid
The evaporative leak detection diagnostic strategy is based on applying a vacuum to the EVAP system and monitoring the vacuum decay rate. The Vehicle Control Module (VCM) monitors the vacuum level via the fuel tank pressure sensor input. At an appropriate time, the EVAP purge solenoid and the EVAP vent solenoid turn ON, allowing the engine vacuum to draw a small vacuum on the entire evaporative emission system. If a sufficient vacuum level cannot be achieved, a large leak or an EVAP system malfunction is indicated. The following conditions can cause this problem:
* A disconnected or malfunctioning fuel tank pressure sensor
* A missing, malfunctioning, improperly installed, or loose fuel cap
* A disconnected, damaged, pinched, or blocked EVAP purge line
* A disconnected or damaged EVAP vent hose
* A disconnected, damaged, pinched, or blocked fuel tank vapor line
* A disconnected or malfunctioning EVAP purge solenoid
* A disconnected or malfunctioning EVAP vent solenoid
* An open ignition feed circuit to the EVAP vent or purge solenoid
* A damaged EVAP canister
* A leaking fuel sender assembly O-ring
* A leaking fuel tank or fuel filler neck
Any of the above conditions can set a DTC P0440.
CONDITIONS FOR RUNNING THE DTC
* No active MAP sensor DTCs
* No active TP sensor DTCs
* No active VS sensor DTCs
* No active O2 sensor DTCs
* No active ECT sensor DTCs
* No active IAT sensor DTCs
* DTC P0125 not active
* The system voltage is between 10-17 volts
* The fuel level is between 12.5-87 percent .
* The ECT is between 4°C-30°C (39°F-86°F)
* The IAT is between 4°C-30°C (39°F-86°F)
* The cold start temperature difference (ECT minus IAT) is less than 1.5°C when the IAT is more than the ECT or 8°C when the ECT is more than the IAT
* The BARO is more than 73 kPa
CONDITIONS FOR SETTING THE DTC
The EVAP system is unable to generate a vacuum more than a calibrated value over a specified period of time.
ACTION TAKEN WHEN THE DTC SETS
* This is a type A DTC that behaves like a B type, in which the VCM illuminates the MIL after the second key cycle.
* The VCM stores the conditions that were present when the DTC sets as a Freeze Frame/Failure Records data.
CONDITIONS FOR CLEARING THE MIL OR DTC
* The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
* A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
* Use a scan tool in order to clear the DTCs.
DIAGNOSTIC AIDS
IMPORTANT: An accurate indication of fuel level is required for the VCM to properly pass or fail this DTC. Always diagnose fuel level sensor DTCs before performing this DTCs diagnostic table. Always check for fuel level sensor DTCs stored in history.
Check for the following conditions:
* A loose, missing, damaged, incorrect or improperly installed fuel cap
* Missing or damaged O-rings at EVAP canister fuel vapor and purge line fittings
* A cracked or punctured EVAP canister
* A damaged or disconnected EVAP purge line, vent hose or fuel tank vapor line
* Incorrectly routed or damaged EVAP system purge and vapor lines
* A poor connection at the VCM. Inspect the harness connectors for the following conditions:
* Backed out terminals
* Improper mating
* Broken locks
* Improperly formed or damaged terminals
* poor terminal to wire connection
* A damaged harness - Inspect the wiring harness to the EVAP vent solenoid, EVAP purge solenoid and the fuel tank pressure sensor for an intermittent, open or short circuit.
* A kinked, pinched or plugged EVAP purge or fuel tank vapor line - Verify that the lines are not restricted.
Refer to Evaporative Emission (EVAP) System Cleaning before starting repairs. Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
Diagnostic Chart (Part 1 Of 4)
Diagnostic Chart (Part 2 Of 4)
Diagnostic Chart (Part 3 Of 4)
Diagnostic Chart (Part 4 Of 4)
TEST DESCRIPTION
The numbers below refer to the step numbers on the diagnostic table.
3. Inspect the service port. Make sure that the valve core is not damaged. If the service port is suspect of leakage use the following procedure: Disconnect the purge line from the EVAP purge solenoid valve. Connect a hand vacuum pump to the service port by placing the hose/adaptor over the unthreaded end portion of the service port. Apply vacuum to 5 inches Hg. If the vacuum does not hold replace the entire purge line which contains the service port.
4. If the vehicle passes the Service Bay Test then an intermittent leak or restriction had occurred. Check the fuel tank cap for a possible loose or OFF condition that may have caused this DTC to set. If the Service Bay Test can not be run, proceed to step 5. If a fault is not currently present the diagnostic table steps will return you to step 3.
9. Refer to the information supplied with the EVAP pressure/purge diagnostic cart on proper setup and adjustment procedures.
10. With pressure applied it may be necessary to disconnect the EVAP lines at the components to verify that a line or component is not restricted. A restriction would prevent a vacuum (or the step 9 test pressure) from forming in the fuel tank.
22. An EVAP pressure sensor that does not correctly respond to vacuum (or pressure) will cause this DTC to set. The EVAP pressure sensor monitors a range from 7.5 inches H2O of pressure to -17.5 inch H2O of pressure (v
  #12
EvansBlue's Avatar
P0452
SCHEMATIC:
CIRCUIT DESCRIPTION
The fuel tank pressure sensor responds to changes in the fuel tank pressure or vacuum. This information is used in order to detect vacuum decay or an excessive vacuum during the EVAP diagnostic routing. The fuel tank pressure sensor signal voltage to the VCM varies from a minimum OF about 0.1 volts with pressure in the fuel tank to above 4.0 volts with a high vacuum in the fuel tank.
The fuel tank pressure sensor display on the scan tool has an auto zero feature which occurs at each ignition cycle and is corrected according to the barometric pressure. Because of this, the fuel tank pressure sensor display may not accurately reflect the actual output of the sensor or the conditions within the fuel tank.
The fuel tank pressure sensor diagnosis table is intended to isolate and diagnose the electrical problems with the sensor wiring or the sensor.
The ignition switch is in the RUN position.
The fuel tank pressure sensor voltage is less than 0.1 volt for more than 5 seconds .
The VCM turns ON the MIL after 2 consecutive driving cycles with the fault active.
DIAGNOSTIC AIDS
1. Inspect the control module harness connectors for the following conditions:
o Improper mating
o Broken locks
o Improperly formed
o Damaged terminals
2. Inspect the wiring harness for damage. If the harness appears to be OK, observe the fuel tank pressure sensor display on the scan tool while moving the connectors and the wiring harnesses related to the sensor. A change in the display will indicate the location of the fault. Refer to Wiring Repairs in Diagrams.
TEST DESCRIPTION
5. If the VCM recognizes the high signal voltage, the VCM and the wiring are okay.
Old Apr 18, 2008 | 5:52 PM
  #13
EvansBlue's Avatar
P0446
Schematic
CIRCUIT DESCRIPTION
The Vehicle Control Module (VCM) monitors the performance of the Evaporative Emission (EVAP) system by applying a predetermined level of vacuum to the EVAP system and monitors the vacuum decay rate. The VCM sets this DTC if the vacuum decay rate is more than a predetermined value. The VCM monitors the amount of vacuum and the amount of pressure in the EVAP system by monitoring the fuel tank pressure sensor. For this DTC the VCM turns ON both the EVAP purge valve and the EVAP vent valve when the Conditions for Running the DTC are met. This applies an engine vacuum to a closed EVAP system. The VCM turns OFF both the EVAP purge valve and the EVAP vent valve when the system reaches a correct amount of vacuum. The EVAP system should quickly RELEASE the vacuum in the EVAP system with the EVAP Purge Valve OFF and the EVAP Vent Valve OFF (open). This test indicates a blocked or restricted EVAP Vent path, if the EVAP system tails to release the vacuum quickly enough.
* The fuel level is more that 12.5 percent but less than 87 percent .
* The system voltage is between 10-17 volts .
* The ECT is between 4°-30°C (39°-86°F) .
* The IAT is between 4°-30°C (39°F-86°F) .
* The BARO is more than 72 kPa .
* The change in fuel tank vacuum is less than 0.6 inches of H2O, or the change in fuel level is less than 8 percent .
* The fuel tank vacuum level remains above a calibrated value for a specified number of seconds.
The VCM fails to detect a drop in the EVAP system vacuum over a calibrated number of seconds with the vent solenoid open.
* The VCM illuminates the MIL during the first key cycle in which the DTC sets.
DIAGNOSTIC AIDS
IMPORTANT: An accurate indication of fuel level is required for the VCM to properly Pass or Fail this DTC. Always diagnose fuel level sensor DTCs before performing this DTCs diagnostic table. Always check for fuel level sensor DTCs stored in History.
* A stuck closed EVAP vent valve
* A restricted or stuck closed fuel tank rollover valve
* A poor connection at the VCM: Inspect the harness connectors for the following conditions:
* Improper mating
* Broken locks
* Poor terminal to wire connection
* A kinked, pinched or plugged EVAP purge, or fuel tank vapor line - Verify that the lines are not restricted.
Refer to Evaporative Emission (EVAP) System Cleaning before starting repairs. See: Emission Control Systems\Evaporative Emissions System
Diagnostic Chart (Part 1 Of 3)
Diagnostic Chart (Part 2 Of 3)
Diagnostic Chart (Part 3 Of 3)
TEST DESCRIPTION
4. If the vacuum stored in the EVAP system is quickly released then an intermittent system restriction or failure of the EVAP vent valve or the EVAP fuel tank pressure sensor may have occurred.
5. Checking the vapor canister and the EVAP vent valve for restriction.
9. An EVAP pressure sensor that does not correctly respond to pressure (or vacuum) will cause this DTC to set. The EVAP pressure sensor monitors a range from 7.5 inches H2O of pressure to - 17.5 inch H2O of pressure (vacuum). In order to test the EVAP pressure sensor for pressure response SEAL the system with the scan tool and use the EVAP pressure/purge diagnostic cart to apply pressure to the system. Compare the pressure gauge (in H2O) on the diagnostic cart to the EVAP pressure sensor reading on the scan tool.
Old Apr 18, 2008 | 5:55 PM
  #14
EvansBlue's Avatar
B2725 - Active Transfer Case Mode Switch Malfunction
Schematic
Circuit Description
The range/mode switch circuit consists of four normally open switches. The transfer case shift control module supplies a regulated 8 volts, DC to the switch through the 8 V Reg circuit. The current travel through a 9.09 K Ohm resistor located inside the switch. Then returns current to the transfer case shift control module through the switch signal circuit.
The transfer case shift control module constantly monitors this signal voltage to determine the condition of the mode switch circuit. If no buttons are pressed, and the transfer case shift control module detects a voltage level outside the possible range (approximately -0.5 to 1.0 volts) for longer than 5 minutes, the transfer case shift control module will set this DTC or if a button is held down or sticks for a period longer than 5 minutes.
When each of the switches is depressed they will complete a circuit through their own specific resistor. The transfer case shift control module continuously monitors the switch input to determine whether the 4HI, AUTO 4WD, 2HI, and 4LO button selections are made by the driver. Neutral may be obtained if the following conditions are met:
* The engine is running.
* The automatic transmission is in neutral (or the clutch pedal is depressed on a manual transmission application).
* The vehicle speed is below 3 MPH.
* The transfer case is in the 2HI mode.
Once these conditions have been met, pressing and holding both the 2HI and 4LO buttons for 10 seconds will shift the transfer case into neutral, turning on the red neutral indicator lamp.
Conditions for Setting the DTC
* The system constantly monitors the voltage on the switch signal circuit.
* If the system detects a voltage level outside the possible range produced when no buttons are depressed, (approximately -0.5 to 1.0 volts) , the DTC is logged.
Action Taken When the DTC Sets
* All shifting will be disabled.
* The SERVICE indicator (4WD/AWD) lamp will be latched on for the remainder of the current ignition cycle.
Conditions for Clearing the DTC
* The transfer case shift control module will clear the current DTC if the condition for setting the DTC no longer exists.
* A history DTC will clear after 100 consecutive ignition cycles without a fault present.
* History DTCs can be cleared using a scan tool.
Test Description
The number(s) below refer to the step number(s) on the diagnostic table.
2. Tests for proper operation of the transfer case mode select switch.
3. Tests for proper voltage supply to the transfer case mode select switch.
4. Tests the transfer case mode select switch for proper resistance values in all switch states.
5. Tests the switch signal circuit for a short to voltage.
6. Tests the switch signal circuit for an open or a short to ground.
7. Tests the switch signal circuit for a short to the 8 V Reg. circuit.
8. Determines whether the 8 V Reg. circuit is greater than or less than the specified voltage.
9. Tests the 8 V Reg. circuit for a short to voltage.
10. Tests the 8 V Reg. circuit for a short to ground.
Old Apr 18, 2008 | 5:56 PM
  #15
EvansBlue's Avatar
C0305
NVG 236/246-NP8 Two-Speed Automatic
Circuit Description
The Front Propshaft Speed Sensor is a Permanent Magnet (PM) generator. The PM generator produces a pulsing AC voltage. The AC voltage level and number of pulses increases as speed increases. The transfer case shift control module converts the pulsating AC voltage to a propshaft RPM which is used for calculations, and to monitor the difference between the front and rear propshaft speed. It is also used in the AUTO 4WD mode of operation to determine the amount of slip and the percent of torque to apply to the front axle. The module only looks at this input when the vehicle is in AUTO 4WD mode, 4H, and 4L ranges. The propshaft RPM can be displayed with a scan tool.
This DTC detects an open, short to ground, short to voltage or faulty sensor.
The system will log the DTC if the front propshaft input indicates a speed of less than 16 RPM for 30 seconds while all of the following are true:
* Transmission is NOT in Park/Neutral
* Engine is running
* Front axle is engaged
* Vehicle Speed On Class 2 Data bus exceeds 10 mph
* All Shifts to AUTO 4WD mode will be disabled. If the current mode is AUTO 4WD, the system will not allow any further adaptive events (correct wheel slip).
* The Service indicator (4WD/AWD) lamp will be latched on for the remainder of the current ignition cycle.
* The transfer case shift control module will clear the DTC if the condition for setting the DTC no longer exists.
Test Description
2. Tests to see if the malfunction is intermittent.
3. Tests the internal resistance of the propshaft speed sensor.
4. Tests to see if the propshaft speed sensor can generate a sufficient amount of AC voltage.
5. Tests the FSS LO circuit for a short to ground, a high resistance, or an open.
6. Tests the FSS HI circuit for a short to ground, a high resistance, or an open.
7. Tests the FSS LO circuit for a short to voltage.
8. Tests the FSS HI circuit for a short to voltage.
9. Tests the FSS LO circuit for a short to the FSS HI circuit.
[hr]
NVG 136-NP4 (One Speed Automatic)
Circuit Description
The Front Propshaft Speed Sensor is a Permanent Magnet (PM) generator. The PM generator produces a pulsing AC voltage. The AC voltage level and number of pulses increases as speed increases. The transfer case shift control module converts the pulsating AC voltage to a propshaft RPM which is used for calculations, and to monitor the difference between the front and rear propshaft speed. it is also used in the AUTO 4WD mode of operation to determine the amount of slip and the percent of torque to apply to the front axle. The propshaft RPM can be displayed with a scan tool.
* Transmission NOT in Park/Neutral
* Engine is running
Test Description
Old Apr 18, 2008 | 5:57 PM
  #16
EvansBlue's Avatar
C0265 & C0266 Explained
Circuit Description
The EBCM internal relay supplies battery voltage to all six valve solenoids and the pump motor. The low side of each solenoid coil has a feedback circuit to the EBCM microprocessor. When the relay is commanded off, feedback voltage is low. When the EBCM relay is commanded on, feedback voltage is high.
* The ignition is ON.
* The IPC bulb check is complete.
* The vehicle is moving at a speed greater than 5 km/h (3 mph).
C0265
The EBCM microprocessor detects low feedback voltage from all of the valve solenoids when the relay is commanded on.
C0266
The EBCM microprocessor detects high feedback voltage from all of the valve solenoids when the relay is commanded off.
* The ABS and BRAKE indicators are commanded on.
* The ABS is disabled for the remainder of the ignition cycle.
* The EBCM aborts all other self-tests for components that are powered by the relay (DTC C0265 only).
* Repair the condition(s) responsible for setting the Diagnostic Trouble Code (DTC).
* Use a scan tool in order to clear the DTC.
Diagnostic Aids
C0265
An intermittent DTC C0265 may be caused by a problem in the battery positive voltage circuit wiring or connection to the EBCM.
Thoroughly inspect connections or circuitry that may cause an intermittent malfunction. Inspect for the following:
* Improper mating
* Broken locks
* Corrosion
* Poor terminal-to-wiring connections
* Physically damaged wiring
* Wiring broken inside the insulation
C0266
An intermittent Diagnostic Trouble Code (DTC) C0266 can be set by a number of internal EBCM problems. If DTC C0266 continues to set intermittently, replace the EBCM.
Test Description
A 310 ABS System:
A 325 ABS System:
Power & Ground Schematics:
A 310 ABS System:
A 325 ABS System:
The number below refers to the step number on the diagnostic table.
4. This step tests if the battery positive voltage circuit can supply adequate power to the EBCM internal relay.
basslover1
Sep 18, 2014 2:59 AM
cham88
Jan 30, 2011 11:48 AM
DJ420
Oct 9, 2009 2:03 PM
livingwill
Jul 22, 2006 4:44 PM
sdimess
Dec 18, 2005 11:58 PM
