S-10 & Blazer 1982-2005
S10 Dropping RPM in coast
Old May 22, 2014 | 10:07 PM
AndyS10's Avatar
Default S10 Dropping RPM in coast
When I'm driving over 80k and take my foot off the accelerator to coast, after about 6-10 secs the RPMs drop right off, like as if I have a govenor and my truck makes a weird sound. As soon as I put my foot back on the accelerator it goes back to normal. I can prevent this from happening if I keep the accelerator or the brake even slightly depressed, but this is hard on my brakes and gas! Can anyone help me out in what is happening?
Old May 25, 2014 | 7:59 AM
Welcome to the forum....
If I understand your question correctly, your RPM's are dropping when you let off the gas... this is normal, as the engine is no longer accelerating so the RPM's drop...the torque converter does not ( for the most part) transfer the wheel spin back to the engine so even though you are rolling at highway speeds but not accelerating the engine is mostly at idle
Old May 26, 2014 | 10:40 PM
AndyS10's Avatar
Thanks for the response, but, you didn't fully understand. I realize that when I take my foot off the accelerator, of course the RPMs naturally slowly decline as the vehicle is no longer accelerating. With my truck, if I take my foot off the accelerator on a decline, my RPMs don't just gradually reduce with speed, but they completely drop off...as if my truck has a govenor and it makes a weird sound. If I were to depress the accelerator or the brake, then this doesn't happen.
So, this is not a normal thing and noone I have talked to, including the Chevy dealership has been able to understand or be able to help in any way. But I do know this is not normal.
I am thinking it is either fuel pump, tranny or transfer case related, but I don't know for sure.
Old May 27, 2014 | 6:23 AM
sledge.impy's Avatar
How long have you had this vehicle? How long have you had this problem?
This sounds like normal modern day automatic transmissions.
Did you have the transmission fluid changed recently?
Old May 28, 2014 | 10:53 PM
AndyS10's Avatar
Thanks sledge.impy. I have not had the tranny fluid changed recently, but I have had it checked and it's supposedly ok. I have had the truck since 2009. When I took it to the dealership, I tried to explain that the day before this problem started, I had it parked on a steep decline and my fuel gauge indicated empty for over three hours. They thought I wanted my fuel gauge checked, but I didn't, as I do know that slopes create a change in the gauge. My point was that, that was the only thing I could think of that would have been different for my truck and I thought maybe something had been damaged or dry too long or something, as this only seems to happen when I'm coasting downhill, not up... :s
Chevrolet Forum News
Nov 5, 2013 5:08 PM
dwsmith43
Aug 17, 2012 12:33 PM
nemo3xm
Aug 30, 2011 3:37 PM
buddahpwn1
Feb 5, 2008 7:20 PM
