S-10 & Blazer 1982-2005
S10 tensioner
Old May 26, 2019 | 6:11 AM
228stang74's Avatar
Default S10 tensioner
I changed my tensioner on my 1996 s10 with a 2.2 4 cylinder because it was making a rattling noise. But the new one is making the same noise it looks to me that when the engine is cold with the a/c running that it is hitting the pulley on the crank can anyone tell me if I can put a spacer between the block and the tensioner to stop this noise because it sounds like the engine is about to come apart until it warms up
Old May 26, 2019 | 7:21 AM
Did you also change the belt? The belt may stretched or you have the wrong belt on there that might be a bit too long. Adding a spacer will put the tensioner out of alignment with the other pulleys.
Old May 26, 2019 | 9:20 AM
Irish_alley's Avatar
I'm here for the party
what engine is is your truck? are they the same tensioner?
Old May 27, 2019 | 8:33 PM
228stang74's Avatar
Yes I changed it at the same time
228stang74's Avatar
It's the 2.2 4 cylinder
Old May 27, 2019 | 8:47 PM
sorry i completely misread your most. was reading as you took a used tensioner off another truck with a 2.2 and put it on yours.
i there play on any other pullies?
