S-10 & Blazer 1982-2005
Smell gas leak. Injector valve o-rings?
Old Jan 6, 2008 | 5:33 PM
Manor_Mullet's Avatar
Default Smell gas leak. Injector valve o-rings?
Problem: Smells like gas, strongest on the passenger side, exterior, after shutting off. The leak does not show up on the ground. Kind of smell it while driving, too. Smell increases while idling.
Backround: I recently replaced my fuel filter, but long after it was due. It was clogged and full. Looked likea mixture of chocolate syrup and coffee.
1.)What's the most likely source of the leak?Injector valve o-rings? I count 12 o-rings to replace (2 per injector + 2 on press regltr + 2 on fuel feed). All 12 look like a pain to get to.
2.) Do shops have leak detector or method to pinpoint the leak to a single injector?
3.) Are there any other suspects for the cause of the leak? Maybe the intake gasket? Gasline near the fuel filter.
Old Jan 7, 2008 | 5:07 PM
EvansBlue's Avatar
Default RE: Smell gas leak. Injector valve o-rings?
May be.. but have you checked all the lines and everything? I see its a 95, so you may definately want to make sure the throttle body isn't leaking.
Old Jan 13, 2008 | 3:30 AM
No, haven't checked the throttle body. Dealer diagnosis wasall 4 fuel injectors need to be replaced. I don't believe him so I'll probably start by replacing just the o-rings.
Scott Kelly
Apr 13, 2011 1:58 PM
Irv
Aug 25, 2009 5:46 AM
matto210
Apr 28, 2009 8:18 PM
ourblackmad
Apr 29, 2008 1:35 PM
dlatner
Jul 21, 2006 7:43 PM
