S-10 & Blazer 1982-2005
Stalling
Old Aug 16, 2019 | 11:18 PM
Matthew Muller's Avatar
Default Stalling
I have a 2001 LS 2WD. Issue I'm having is when I have the AC Compressor High pressure switch and the MAF connected the engine stalls out almost immediately after cranking. Disconnect either and it runs just fine. Any thoughts?
Old Aug 18, 2019 | 5:42 AM
oilcanhenry's Avatar
Need to run some OBD II codes for us. Lots of auto parts stores will run the codes for you, if you don't want to buy a code reader.
Have you had your A/C pressures checked?
Also you might want to clean the MAF, but.sometimes they go bad without throwing a code, IME..
Satyr
Jun 8, 2016 7:19 PM
Danimal669
Nov 12, 2012 9:34 PM
wmpaul1010
Feb 26, 2009 8:29 PM
tjlandrover
May 9, 2008 4:16 PM
tjlandrover
May 7, 2008 6:16 PM
