S-10 & Blazer 1982-2005
Starter sometimes works
Old Mar 15, 2008 | 10:18 AM
aikenm's Avatar
Default Starter sometimes works
Sometimes the starter will clunk, but not turn over. It started after the 1st time I swapped the starter. I hav edisabled the clutch switch, moved the relays behind the radio . It doesnt matter if it is hot or cold. Then sometimes it will work for days without failing. Should i replace the starter power cable?
Old Mar 15, 2008 | 2:03 PM
bobbie95poca's Avatar
Default RE: Starter sometimes works
I had the same problems with a blazer and it was the powercable from the starter to the battery. Once i replaced it I had no issues.
02suburban
Jan 19, 2015 12:33 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
brenande
Jan 27, 2008 12:40 AM
DerekMLAbbie
Jul 30, 2007 2:37 PM
