S-10 & Blazer 1982-2005
Starting Issue
Old Feb 18, 2016 | 3:25 PM
billyh's Avatar
Default Starting Issue
Hi Guys. I have an inquiry and was hoping someone here could possibly help out.
Scenario: Get in. Put the key in. Turn over. Starts right up.
Go to work. Awesome.
Leave work. Put the key in. Turn. nothing. No sound from the starter at all. All of the lights are on and the Battery is at around 12. After turning the key (about 50 times) it will start up. Ive had the battery, starter and alternator checked and was told that the starter wasnt reading "perfectly", but seemed fine.
Any Ideas? Thank you.
Old Feb 19, 2016 | 11:42 AM
Check your battery cables at both ends for loose or corroded connections.
