Stuck in 4 LO
Hello new to this Forum as of today. I have a 2000 Blazer that is stuck in 4 Low. Mine has the 4 Auto, 2 HI. neutral. 4 hi and 4 low buttons. When I tried to get it out of 4 low I put it in neutral and pushed the 2 Hi button and did hear some clicking like it was trying to shift out of 4 low but it stayed in 4 low. Now there is no lights on the switches and it just says to Service 4wd.
Any ideas as to where to start the repair?
i'm having the same issues,best way to fix it is to disconnect battery negative termanal,wait a few minutes and re-connect cable to battery........still having the same issues, also noticed the other day while driving it if you brake to fast it will cause the 4lw light to blink but never switches over thank god........... guess we have know one here to help. time to move on i cant afford a repair shops prices
Relaced that but it didnt help, turns out the pigtail to the tccm wasnt making a good connection and everybump would cause the lights to go nutts and lock into 4low if i stopped to switch from drive to reverse, waiting till this weekend so i can grab one out of a junk yard, pigtail and tccm
We had the same issue with our 2000 blazer. It turned out to be the computer control switch that is located on the top of the transfer case. Once that was replaced it ran fine. Good luck.
BigblackHo3
April 5th, 2013 8:54 AM
