S-10 & Blazer 1982-2005
Sudden valve chatter/loss of oil pressure (?)
Old Jun 9, 2017 | 1:25 AM
snydwalker76's Avatar
Default Sudden valve chatter/loss of oil pressure (?)
Hi! Just bought an '88 GMC s15 with a 2.8L V6. It has run beautifully for the two weeks I've had it...very strong and not leaking any oil. When getting off the freeway tonight though, all of a sudden I heard the chattering of the valves like they were not getting oil. I made the turn off the freeway and the engine shut off. I waited a couple minutes and turned the engine back on, and drove it just enough to get it out of the road and into a grocery store parking lot. I checked the oil and it was completely full.
Any ideas? Again, this happened SUDDENLY with no indication of anything starting to go wrong previously. Thanks for the help!
Old Jun 9, 2017 | 7:28 AM
Does the oil pressure gauge read very low? Was the oil pressure good when you first bought it? Did it drop from good oil pressure gradually or just go from good to bad all at once?
Old Jun 9, 2017 | 9:45 AM
Hi! Thanks for the quick reply. The oil pressure gauge is actually buried at the TOP, so I assume it is not working. Again, it has ran perfectly for about 300 miles over the last couple weeks, and the valve chatter happened pretty suddenly. Hopefully this helps...let me know if you need any more info. Thanks!
