S-10 & Blazer 1982-2005
Tire area problem
Old Jul 7, 2008 | 4:45 PM
Lady's Avatar
Default Tire area problem
The back left tire area where the breaks are concealed on my 1994 S10 (automatic) is getting hot. I went to give it a washing today and when I sprayed the back left tire it steamed. Any help on what might be going on?
Old Jul 7, 2008 | 8:42 PM
old dog's Avatar
Default RE: Tire area problem
better pull a wheel and drum sounds like brake's dragging ,check the emergency brake pedal to see if it was applied ,or the cable stuck .
Old Jul 7, 2008 | 9:43 PM
EvansBlue's Avatar
If it is a disc brake, its probably normal, but don't spray the rotor directly with water. It will warp. [/align][/align]If its a drum, then it may be over-adjusted. You can just use a brake spoon to crank the adjuster back just a little.[/align]
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
lauraherota
Oct 19, 2011 9:04 AM
bamafutbal
Jul 29, 2010 9:24 PM
