S-10 & Blazer 1982-2005
trying to hook up a radio
Old Nov 22, 2007 | 9:33 AM
wormiebj123's Avatar
Default trying to hook up a radio
I am tryin to install a radio into my 1991 s10 cameo el, BUT whoever installed the last one cut the wiring harness totally out for some reason. They also plug all the wires into the cigaratte lighter (and how they did this i have NO clue) but im re doing all the wiring but dont no what i could use for a remote wire. What could I use for this????
Old Nov 22, 2007 | 10:09 AM
EvansBlue's Avatar
Default RE: trying to hook up a radio
look in your fuse panel and find the fuse labeled 'Radio battery" or "Radiosignal" and piggyback your signal wire with that fuse.
Old Nov 22, 2007 | 10:29 AM
thank for the quick reply man. i know VERY lil about cars i wont lie but the only fuse i have that says anything about a radio says just that RADIO ha so i was just wondering if that would be the right thing
Old Nov 22, 2007 | 1:13 PM
EvansBlue's Avatar
yeah, just get a test light and check to see if the fuse comes on when you turn the key back.
Old Nov 23, 2007 | 12:34 PM
wat could the problem b if whenever i turn the truck off it takes all of my programed stations and bass settings off??
Old Nov 23, 2007 | 4:34 PM
EvansBlue's Avatar
The signal wire turns it on and off. The radio fuse is probablyfor the power supply for the radio. Are you sure you don't have a fuse for 'Radio battery' or 'radio signal? Check the fuse diagram in your owners manual for any fuse thats related to the radio.
jr2007silverD
Aug 26, 2010 9:45 AM
cptvito
Mar 23, 2009 3:49 PM
cptvito
Mar 19, 2009 8:52 AM
