What fluid to use for 98 s-10 blazer
Im repairing a leaking seal in my transfer case. I was wondering what kind of fluid to use to fill it up with? I was told two different things... transmission fluid and 80/90 gear oil. Which one?
RE: What fluid to use for 98 s-10 blazer
i was always told to put ATF in the transfer case, gear oil in the newer (mid to late '80's and up) tranfer cases and manual transmissions is to thick for the bearing clearances, and will not lubricate properly.
Your "Owners Manual" will list the part number to use. Some fluids are VERY specific to the application and I suggest you get your recommended lubricant at the local Chevy Dealer.
If it's a NVG-136 one speed auto than use the Auto-trak II but if it's the NVG-233 two speed selectable than use manual trans fluid part #88861800
joestacey06
June 9th, 2012 10:29 PM
John O
March 31st, 2010 2:29 AM
DeHartShadow
March 28th, 2010 10:10 PM
junklady
October 28th, 2009 6:01 PM
