S-10 & Blazer 1982-2005
What fluid to use for 98 s-10 blazer
Old Oct 29, 2006 | 9:21 AM
ultra7350's Avatar
Default What fluid to use for 98 s-10 blazer
Im repairing a leaking seal in my transfer case. I was wondering what kind of fluid to use to fill it up with? I was told two different things... transmission fluid and 80/90 gear oil. Which one?
Old Oct 29, 2006 | 11:31 AM
70mopar's Avatar
Default RE: What fluid to use for 98 s-10 blazer
i was always told to put ATF in the transfer case, gear oil in the newer (mid to late '80's and up) tranfer cases and manual transmissions is to thick for the bearing clearances, and will not lubricate properly.
Old Oct 30, 2006 | 3:36 PM
SLJ2137694's Avatar
Your "Owners Manual" will list the part number to use. Some fluids are VERY specific to the application and I suggest you get your recommended lubricant at the local Chevy Dealer.
Old Oct 30, 2006 | 8:36 PM
ZX1100F1's Avatar
These New Venture Transfer Case's work real well on Auto-Trak II Fluid GM P/N 12378508
Old Oct 30, 2006 | 11:35 PM
NCHEVYHEVN's Avatar
If it's a NVG-136 one speed auto than use the Auto-trak II but if it's the NVG-233 two speed selectable than use manual trans fluid part #88861800
joestacey06
Jun 9, 2012 10:29 PM
John O
Mar 31, 2010 2:29 AM
DeHartShadow
Mar 28, 2010 10:10 PM
junklady
Oct 28, 2009 6:01 PM
