S-10 & Blazer 1982-2005
What kind of trailer hitch?
Old Nov 18, 2007 | 11:42 PM
kbrown's Avatar
Default What kind of trailer hitch?
Thebed of my 96' S10 has the pointed flares and step bumper, but i didn't think the trailer hitches i saw would work. They all look like there for the ones with a smooth bumper and step all the way across. But mine has the dip in the center, and i was worried if the hitch i get will bend down low enough to clear the bumper. i looked at reese, draw tite, and hidden hitch. So if someone has ran into the same thing please let me know what kind you have and style if possible?
Old Nov 19, 2007 | 8:04 AM
EvansBlue's Avatar
Default RE: What kind of trailer hitch?
They will work. Just make sure you have the correct model for a 96.
Old Nov 19, 2007 | 1:11 PM
dragonrpc's Avatar
I found one through pep boys, for my 94' (the truckhad just a bumper ball hole) although it was rated, I bought a $120 class III and Pepboys installed it for free (I later discovered its an easy DYI - bolts on the frame bolts) - then I just bought a 4-wire "crimp" on for lights to existing brake/blinker. as your other responder stated, just get the right year/model
Old May 23, 2008 | 1:00 PM
jwoo06's Avatar
Back from the dead! kbrown, did you ever find a hitch that worked?
Old May 23, 2008 | 6:54 PM
pegasauraus's Avatar
I've been looking for something sturdier than what I got from the factory design. Do you know of any heavy-duty's?
Old May 23, 2008 | 7:00 PM
jwoo06's Avatar
How heavy-duty? AutoAnything has got a bunch of trailer hitches, you could probably get whatever you need from them.
Old May 23, 2008 | 10:18 PM
old dog's Avatar
hey kbrown you will have no problem at all .drawtite #75051 hiddenhitch #87525 reese #33053 all have a rating 3500 lb 350 lb tounge weight .when you use weight distribution bar's it ups it to 6000 lb 750 lb tounge weight .they all bolt on no hole's need to be drilled .i used to sell them ,the worst problem we had was having the bumper bent down .
jacque1
Dec 22, 2014 10:59 AM
07summitwhite
Apr 24, 2007 12:08 AM
Biggmon
Mar 8, 2007 11:32 PM
bigtrucks
Jul 5, 2005 10:59 PM
