S-10 & Blazer 1982-2005
wheel bearing or ball joint, maybe???
Old Sep 10, 2007 | 9:55 AM
reds_21's Avatar
Default wheel bearing or ball joint, maybe???
I have a 2002 Chevy S-10, and i am having some issues with my front wheels.
can anyone tell my a symptom that a ball joint could be going???
also, if replacing a wheel bearing, is it wise to replace both sides rather than the one that is making noise? also, is it wise to replace the whole hub assemblyor only the bearings?
is there a manufacturer that anyone can reccommend over another? i dont wanna be changing things out in 4 months due to poor quality!!!
thank you for your help in advance!!!
Old Sep 10, 2007 | 6:04 PM
kcb37's Avatar
Default RE: wheel bearing or ball joint, maybe???
Take it to a good shop and have them look at the ball joints with you. If it is a good shop they will show you how to check them. You should change both bearings and races if you don't put new rotors on too.
Old Sep 10, 2007 | 6:15 PM
reds_21's Avatar
thanks kcb37
jz96z3
Dec 19, 2011 12:47 PM
kellyguinn
Sep 1, 2008 1:40 PM
Kamdon
Jul 15, 2008 6:59 PM
mudderfan
Dec 17, 2007 5:22 PM
nativebroncofan
Feb 13, 2007 3:24 PM
