S-10 & Blazer 1982-2005
window wipers
Old Feb 27, 2006 | 9:46 PM
foxie4's Avatar
Default window wipers
i have a 98 s-10 and i also have selective window wipers. they decide to work on and off, especially when its raining really hard. is this maybe something with the relay, or a motor problem? i could use any help on this one....also, if it is the relay...where the heck is it?!
Old Feb 28, 2006 | 3:38 AM
Chev007's Avatar
Default RE: window wipers
it could be the motor. but to ensure that you're not going to replace the whole thing, check it out with your mechanic. try car parts restoration too for some customization..
Old Mar 7, 2006 | 7:45 PM
dad1442's Avatar
it is the relay. GM had a recall on the problem. I have a 95 s-10 and it did the same thing. lots of luck
Old Apr 10, 2006 | 8:58 PM
ljpierce_ely's Avatar
GM did have a recall on the wiper motor. Actually, as it turned out, it was the little control box mounted to it. I ended up replacing the entire motor and box about 4 months before the recall was originally issued and they would only reimburse for the cost of the box. The entire motor assembly was a bit pricey too.
Old Apr 11, 2006 | 7:39 PM
foxie4's Avatar
well i like the idea of it being a recall so i dont have to pay for it!! someone told me it might be the module and i know that can be pricey to replace. ill have to check out to see if it really is a recall....THANK YOU!!!
justin69
Feb 28, 2015 2:54 PM
pelletman
Feb 3, 2011 7:47 AM
davbell22602
Mar 10, 2010 8:36 PM
MEGBAILEY
Nov 25, 2005 5:37 PM
