S-10 & Blazer 1982-2005
wipers
Old Dec 24, 2007 | 8:30 PM
nativeblazerman's Avatar
Default wipers
I replaced the wiper motor and fuse and my wipers still won't work can anybody help me i was wondering could it be something to do with the signal switch arm it is a 199 chevy blazer
Old Dec 24, 2007 | 10:17 PM
EvansBlue's Avatar
Default RE: wipers
Check to see if the relay is still working 1st.
It is very possible that you have a bad switch. Check all the wires coming to and from the wiper motor, and then the wires at the switch.
I don't know if this will help you much, but this could be the problem: http://www.blazerforum.com/m_56980/tm.htm
Old Jan 4, 2008 | 10:43 AM
quinnman105's Avatar
Default RE: wipers
I had a similar problem like this happen to me. Check to see if the bolts on wiper arms are loose. I had the drivers side wiper flopping all over the place the repair shop just tightened the bolts on both side.
pelletman
Feb 3, 2011 7:47 AM
Z24 Cavalier
May 4, 2006 1:02 PM
foxie4
Apr 11, 2006 7:39 PM
MEGBAILEY
Nov 25, 2005 5:37 PM
