2008 chevy suburban excessive oil loss
Old May 19, 2016 | 7:54 AM
jonhaws's Avatar
Default 2008 chevy suburban excessive oil loss
my suburban just started loosing oil. 3 or more quarts per 3k
looking for some thoughts before I go to the mechanic
whats been the best fix for this 5.3 l engine
Old May 19, 2016 | 10:46 AM
Is it leaking oil or burning oil? Either way it is excessive.
Old May 19, 2016 | 11:34 AM
jonhaws's Avatar
It's burning out some how
Very little signs of leaking underneath
Old May 19, 2016 | 9:46 PM
cleveland63b's Avatar
theres a bulletin on oil consumption in the 5.3s that includes installing an AFM shield on the oil pan and an updated valve cover, worse case scenario replacing piston(s). If you haven't had the updated valve cover installed I would start there and see if it changes anything, or pull the spark plugs and check for fouling
Old May 20, 2016 | 6:18 AM
jonhaws's Avatar
Thank you first time hearing about the sheild. Do you know if
The products are aftermarket or a dealer part ?
Old May 20, 2016 | 6:24 AM
jonhaws's Avatar
Is the bulletin on this site?
