headlight problems
Old Feb 5, 2015 | 6:52 PM
awilson10's Avatar
Default headlight problems
I have a 96 k2500 4x4 5 speed...the weird thing is that when i turn on low beams or left turn signal the windshield wipers come on....what could this be bad switch or ground problem...there is no ground wire going from the frame to the firewall please help thanks
Old Mar 5, 2015 | 10:01 PM
Eighthgenburb_altick's Avatar
I had a similar problem but with my horn and a light whenever I would honk the light would come on, anyways I ended up just taking the steering wheel apart and taking a loose piece of broken plastic out and putting a new fuse in and the problem went away. I realize your issue isn't the same as mine but I would look into the arm coming out of the steering wheel that controls both of the things that are failing you and see if anything is broken of noticeably not how it's supposed to be.
garyv990
Feb 11, 2015 9:52 PM
Pattyswind
Jan 5, 2010 11:27 PM
glennnn
Oct 30, 2009 12:44 PM
jaybull
Jun 20, 2008 10:27 PM
joshuaboudreauxksig
May 4, 2008 4:06 PM
