Low brake pedal
Old Aug 31, 2016 | 6:21 PM
MDBowtie's Avatar
Default Low brake pedal
I have an 07 Tahoe. The brake pedal is firm but low. Has anyone else had this problem.
Old Sep 2, 2016 | 7:24 PM
rear drum brakes or disc?
does the pedal come up when pumped repeatedly?...try this on a test drive
Is the fluid low in the reservoir? If yes, inspect all the brake linings to see if they are near the end of life.
Old Sep 3, 2016 | 7:25 AM
MDBowtie's Avatar
It has rear disc. New brake pads around in the last year. All new calipers and rubber brake lines, fluid flushed and filled. The pedal does come up if pumped several times but goes back down when pressed. Sometimes if holding the brake at a stop light the pedal is firm and then goes down slightly like it's pushing air.
Old Sep 3, 2016 | 4:12 PM
kevinkpk's Avatar
My guess would be the master cylinder
Old Sep 4, 2016 | 12:17 PM
try bleeding the system. if no change it may need a m/c
