5.3 Knock Sensors
Good Evening all!!
I have a 5.3 and have a issues with the dreaded knock Sensors i have replaced them 5 times now and i used acdelco and also replaced the harness. yes i also torqued them down to 15 in/lbs i keep geeting p0327 and p0332 the 4th time i only got the p0327 and so i changed just that one the 5th time but still have the p0327 any ideas
Good Evening all!!
Have you figured your issue out? I've recently replaced mine and have done testing of wires and still get p0237. Thinking PCM maybe
its a circuit low code...meausre the harness for a short to grd...it should show no continuity.
if that tests good....disconnect the harness from the knock sensor...yu should get the circuit hight code....if you don't probably ecm. the fault can only be sensor, wires or ecm.
rule out sensor by replacing
rule out wires by ohm check and voltage drop test
if that test good you replace ecm as that can't be tested.
idsinteriors@srt.com
Jan 16, 2014 4:20 AM
