Help me identify my engine
Old April 28th, 2024, 7:22 PM
23jeg's Avatar
Default Help me identify my engine
Hello, can someone help me identify my engine? The only marking I can find on it is the firing order. It looks like a small block Chevy. It came in the 1957 Bel Air I just bought (project car). I was told it was not the original. The oil filter is a Fram PH-30 and the plugs are Autolite 26 (which I crossed to AC Delco R45TS). Thank you.
Old April 29th, 2024, 7:51 AM
Welcome from Florida. Look for numbers stamped on the block. This will help you.
Small Block Chevy Engine Block casting and code identification (nastyz28.com)
Old May 2nd, 2024, 6:37 PM
23jeg's Avatar
Default Thank you
Thank you for your info. I have no markings on the front. I can't see the back of the block. Someone said it may be a crate engine. I did run the carb numbers. 1963 Chevy.
I'll keep looking, The info you provided will be very helpful when I find something.
Thank you
Old May 3rd, 2024, 12:01 AM
Gumby22's Avatar
Remove the air cleaner for a better view of the rear of the block. The casting number should be on the “ledge” of the block behind the driver side head - it may also be on the lower end of the block, near/under one of the exhaust manifolds.
Here’s another site with number locations and info about them… SBC Casting #’s
mscummings
Nova & Chevy II
October 18th, 2023 4:44 PM
Warsaaf14
December 3rd, 2021 7:20 AM
Cshort6469
October 27th, 2021 6:46 PM
zoomazoomzoom
July 18th, 2020 11:24 AM
Cargirl2017
December 19th, 2016 7:20 PM
Quick Reply: Help me identify my engine
