fuel system disabled
Old June 28th, 2024, 11:05 AM
richard69's Avatar
Default fuel system disabled
01 express 3500; oil got low causing the fuel system to be disabled. Got oil in and vehicle home. Next morning same. anyone know how to enable again? Did reset by way of battery then ecm fuse...nothing.
Old June 28th, 2024, 11:32 AM
How do you know it's disabled? I've never heard of low oil disabling fuel.
Old June 28th, 2024, 12:11 PM
richard69's Avatar
Older vehicles oil sending unit shut vehicle down when pressure was low. Last year same vehicle had an issue during research in a manual I read some oil switches disabled fuel system. Now when van didn't start had seen oil pressure low. While diagnosing didn't hear fuel pump turn on.....did some reset and finally disconnected oil switch van turned on. Problem morning back and now even oil switch off no fuel
Old June 28th, 2024, 1:29 PM
I don't think that's how your van works. It has an oil pressure sensor on top of the engine, which is connected directly the gauge on your instrument panel.
First verify your theory by starting the engine with some starting fluid. If the pump isn't operating then it could be failing or you have a problem in the fuel pump circuit.
RoadTrip (June 28th, 2024)
B1uzcruzin
February 22nd, 2018 7:40 PM
JAMBUS
15
January 23rd, 2017 4:32 PM
flattieslayer
October 5th, 2014 1:03 PM
Smithfamilyof7
June 5th, 2013 8:39 PM
vanmanpdx
July 9th, 2012 2:04 PM
Quick Reply: fuel system disabled
