Engine oil low fill oil
Old Apr 22, 2011 | 7:32 AM
flattieslayer's Avatar
Default Engine oil low fill oil
can anyone help I had got an oil change and was able to reset the button that tells you what % your oil is still good but every time I start the tahoe it says engine oil low fill oil the oil was checked and is at the right level I feel that something must need to be reset
Old Apr 22, 2011 | 11:29 AM
EinST's Avatar
Did you get an oil change because of the "CHANGE ENGINE OIL SOON" or "ENGINE OIL LOW ADD OIL" warning? It sounds like the latter which means the ECM determined a low oil level based on the engine oil level switch circuit.
Old Apr 22, 2011 | 8:05 PM
May be the oil level sensor gone bad. Is Check Engine lite on?
Old Apr 23, 2011 | 3:53 PM
No I went to Texaco express lube my oil percent was down to 10% still good so I went to get it changed. After the oil was changed it still said 10 % oil still good so the guy there showed me how to reset that feature back to 100% good then after that every time I start the car the words engine oil low fill oil show up so I push the mileage button and it goes away until I start the car again and it shows back up. I had them check the oil level and the guys said it was right where it suppose to be and there was no check engine light on
Old Apr 23, 2011 | 5:19 PM
Default 5.3L Oil level Sensor location
So it didn't show up until after the oil change? if so they may have knocked something loose.
Attached is the location of the oil level sensor on the 5.3.
Old Apr 23, 2011 | 10:37 PM
Or did it only show up after they reset the Oil Life back to 100%?
Old Apr 24, 2011 | 9:31 AM
Before I left texaco lube I noticed the oil life needed to be reset and they showed me how to reset it. The very next day when I start the tahoe the message engine oil low add oil comes on but once I push another button it goes off. It did not show up til after the oil change and the message showed up after we reset the oil life button
Old Apr 24, 2011 | 10:14 AM
EinST's Avatar
Did they put in 6 quarts and it hasn't been leaking around the oil filter or drain plug? Am I missing something or in all this there's no mention of you checking the oil level yourself?
Old Apr 24, 2011 | 10:51 AM
I'd check the connection to the oil level sensor, make sure the wires are not pinched or crushed. Its possible the "low" indicator could have been masked by the "change" oil so you didn't see the error until the most current one was cleared...
Old Apr 24, 2011 | 1:48 PM
Sorry I did check the oil level myself and it was fine no leaks
