New tail light pins loose
Old Yesterday, 11:23 PM
Kai Kyle's Avatar
Default New tail light pins loose
Hello all. I purchased 2 new tail light connector plates for a 92 Silverado. The problem I'm having is the pins on the new connector plates are not exactactly the same as the original tail light, so it is making a bad connection causing all sorts of problems. If I try to bend the pins a little to provide some tension they will break inside the plastic of new plate and not work at all, intermittent,etc. I purchased 2 new plates
​​​​​​from Amazon and 1 from oriellys with similar problems. Does any one have a remedy or recommdation for better plates that are exact fit. Thanks, Kai.
Goose57
1988 - 1998 (GMT400)
May 17th, 2020 8:05 AM
Tomahawk4x4
October 16th, 2019 5:33 PM
trailblazer_eddy
May 1st, 2009 4:17 PM
braz28
January 30th, 2009 4:43 PM
mfishgutz
June 25th, 2006 12:20 PM
Quick Reply: New tail light pins loose
