2016 Dashboard Vent replacement
Hi everyone.
I have a 2016 Chevy G2500 van, and the louvers on the dashboard AC vents are broken, or won't close fully on a couple of vents. I found replacement parts and the new vents aren't very expensive.
My question is:
How do these vents come out, and go back in?
It looks like it should just pop out with a little pressure, but I am having a difficult time getting it out and don't want to break the mounting clip on the inside of the dash that it should snap into.
Suggestions?
My question is:
Suggestions?
They just pop right out. Just stick a flat head screwdriver under where they pivot and pop them out. You can pop them out from either side. They do have a top and bottom if you look at them. One side is larger than the other where they click together so they only install one way.
