60° advanced timing to run?
Old Yesterday | 6:36 AM
Mattera350's Avatar
Default 60° advanced timing to run?
1977 010 block 350 sbc bored to a 383 stroker forged internals pink rods dual relief pistons .770/690 cam gear drive timing scorpion intske manifold
truck will refuse to run no matter the timing unless set to 60 degrees advanced doubled checked the cam gear (both dots at 12 o clock position compression stroke) verified tdc with a piston stop as well as the balancer is dead on 0tdc distributor is pointing to cylinder 1. Checked for vacuum leaks spraying everything with starting fluid no fluctuations in idle.
750 elderBrock carb with an electric fuel pump pushing about 8psi. Truck will not idle in gear but will in park. Stock turbo 400 trans with stock convertor
Old Yesterday | 7:38 AM
Welcome from Florida. The cam sprocket dot is supposed to be at 6 o'clock They are supposed to be next to each other..
Old Yesterday | 8:03 AM
Mattera350's Avatar
Yes your correct if cyl 6 was in compression stroke cylinder 1 is in compression stroke which both cam and crank gears are 12 o clock once you rotate and #6 is in compression stroke the dots are 12 and 6
Jay Dee
July 4th, 2022 2:09 AM
Bryan_71-C10
July 30th, 2016 3:00 PM
KGJC616
August 30th, 2010 12:57 PM
cduarte1982
K5 Blazer
May 22nd, 2010 6:26 PM
51 Chevy
November 13th, 2007 8:52 AM
Quick Reply: 60° advanced timing to run?
