2017 5.3 silverado testing fuel injectors
Old Jan 4, 2025 | 11:58 AM
themage_ca's Avatar
Default 2017 5.3 silverado testing fuel injectors
Hi all,
I suspect one of my injectors is shot and I wanted to test the injector with my ohm meter to see if one of them fails the tolerance as I have seen videos on this that seems pretty straightforward. However, after watching a few videos,most of them show only a simple 2 pin connector, but when i opened my connector up, it has 4 pins.
Does anyone know the layout of which pins i use or if there is a different method to test for this sitaution?
My problem is that it the stuttering and misfire code is not consistent. It happens sometimes, and then the truck runs fine for a bit without any issue. I can drive 5m without any problems, then suddenly going up a hill or idling along at 60km/h it stutters for a minute then stops. it is getting worse as time goes by and all the symptoms seems to be a bad/clogged injector, so I was hoping to just check the injectors to further narrow down if its a bad injectors vs, just need to get a proper cleaning.
Thanks in advance.
Old Feb 22, 2025 | 10:52 AM
hiesenberg's Avatar
Originally Posted by themage_ca
Hi all,
Thanks in advance.
did you ever figure it out?
Expresscv
2014 - 2018 (GMT-K2)
Aug 4, 2024 8:59 AM
MLockheed
Oct 22, 2023 7:24 PM
zzsnowman
Dec 16, 2020 9:28 AM
woodrange
Oct 19, 2018 11:14 PM
silverado 1500 2001
Aug 24, 2014 2:59 PM
