1999 Chevy C 1500 Suburban turn signal issue
Old Mar 30, 2026 | 11:13 AM
Goochlin's Avatar
Default 1999 Chevy C 1500 Suburban turn signal issue
Hi, Got my Suburban back from the body shop from having it painted, They replaced the rear taillight and front turn signal assemblies. Been stored for the last 3 months. bringing it home noticed the left turn signal blinks as normal but the right turn signal flashes very fast. There is no flashing from it. I pulled the front assembly and checked the bulbs and . they are good. I removed the right rear taillight assembly and swapped it with my old one they left me. No change. Could they have possibly left a ground wire off.
Old Mar 30, 2026 | 1:18 PM
Goochlin's Avatar
Update, I replaced the turn signal flasher and the the 2 front 1157A bulbs. Same issue.The volt meter on DC flashes OL super quickly when I connect it to brown wire ( ground ) and light green tab that activates the turn signal bulb. It flashes at same as the dash turn signal lamp.
Old Mar 31, 2026 | 8:06 AM
Cusser's Avatar
Sometimes after a paint job, the grounding connection is interrupted by the new paint. Test by temporarily running a separate ground wire.
Old Mar 31, 2026 | 8:25 AM
a55bruce's Avatar
The OL on your meter is the auto range feature trying to switch your meter to the correct voltage range. Find the manual range option on your meter and set it for 20V (depends on the brand)
The brown wire is NOT the ground, the Black wire is ground. Light green (schematic calls it light blue) is the turn signal, the brown is the park lamp.
A sign that you have a bad ground is to look closely at the filaments of the bulb while it's flashing, with the lights OFF. If both filaments are flashing, you might have a missing ground.
Old Mar 31, 2026 | 11:35 AM
Goochlin's Avatar
O.K. Yes the flutter is auto switching. Going to use Simpson meter as it is analog. And my thought was a ground too. Possibly they tampered with my trailer hitch wiring. Going to check that out after it rains here. And will look at it after dark. When I pulled the 2 front bulbs for the parking / turn assembly on the right the little side marker light went back to regular flashing. I swapped out the old right rear tail light assembly thinking possibly it was a bad unit but acted the same. Will post when I get out there. Thanks.
Old Mar 31, 2026 | 1:55 PM
Goochlin's Avatar
Hi, stopped raining. Went out and yes mis quoted wires. Brown marker light green turn signal wire. Black wire shows 22,5 ohms to bumper ground. So I took a wire and connected it to the battery ground and ran it to back of the truck to the black wire on the harness. Bingo lights work! The body shop must have disturbed it. Going to chase the black wire back and repair it once the ground dries up and go underneath truck. Thank you for the help on this. Appreciate the input. She has 135,000 miles on her from Texas. Body is beautiful but had scratches on her and 25 years of sun beating on her. She looks showroom new now.
Old Apr 3, 2026 | 1:05 PM
Goochlin's Avatar
Hi, jumping on the ground issue today. Odd thing also. I put a new battery in it a few days ago. Looks like I am loosing about a volt after a few days. 14.6 volts charging and started out with 12.6 volts after shutting down motor. Each day lost about 2-3 tenths of a volt. This morning it was down to 12.1 volts .Monitoring situation. Checked alternator for diode issues. Did not find anything wrong. So I charged up battery and pulled ground wire. Sitting at 12.6 volts. Will see if I have a bad battery?
Old Apr 3, 2026 | 3:12 PM
Goochlin's Avatar
Hi, Checked under truck and the harness is buried up under truck. So I decided to do a line mans splice on the black ground wire in the right rear tail light pocket. Soldered a good wire to the car's black wire and taped it up. Stuffed it back into the plastic loom and taped up the loom end as factory did. Took a solder connector on the other side and drilled a hole in the light pocket and used an external star washer on both sides. Reinstalled tail light. All working now. So waiting to see if the new battery is bad. Will check it out tomorrow. Thanks for the replies. Appreciate it.
Old Apr 6, 2026 | 3:08 PM
Goochlin's Avatar
Hi all, left the new battery disconnected for 2 days . Stayed at 12.6 volts. This morning I reconnected the battery back When I checked it after connecting it the voltage dropped to 12.4 volts . I decided to disconnect the under hood light and the battery bounced back to 12.6 volts. Have monitored it every 2 hours and it is sitting right at 12.6 volts. So believe the under hood light is causing the drain. When I had the body work done they even went under the hood and washed and detailed the engine compartment. Possible the light got compromised. Will check it for another day but hopefully got this solved. I will take the light off and see what may be amiss with it, Assume it has a mercury switch in it. Will report back in a few days. thanks.
Old Apr 6, 2026 | 3:26 PM
Rednucleus's Avatar
The light should turn off with the hood closed. You could put your meter on the battery to confirm that
