Chevrolet Equinox
Platform: Theta
2020 Equinox P0498 code issue
Old Today | 1:34 PM
rodneyford73's Avatar
Default 2020 Equinox P0498 code issue
Hello all, new member here.
I have a 2020 Equinox LT 1.5 turbo engine. I have been having an issue tracing down a P0498 code. I can clear the code with a scan tool and the code comes right back upon restarting the car. I have checked and replaced the evap vent valve. Checked the ecu fuse and wiring to the evap vent valve. I have not found any problems so far. I have found that if I reset the computer or pulled the ecu fuse and then start the car, the check engine light will be off for as long as the engine is running. If I shut the car off, when I restart it the check engine light comes back on. I am wondering if there may be an issue with the ecm itself. I do not have, nor can a bidirectional scan tool at this time. Could it be that the car needs an ecm refresh? Any help would be very much appreciated. Thank you for your time and knowledge.
EMMY
Aug 7, 2024 3:32 AM
Satyaprakash47
Aug 15, 2022 2:19 PM
PastaMonster
Trax
Feb 10, 2021 10:58 AM
Bethany Demtshuk
Oct 19, 2020 11:52 AM
jamair
Apr 5, 2014 2:28 AM
