Trax Chevrolet's subcompact crossover SUV. This small SUV has a pioneer spirit, with modern technologies that make discovery easy and cargo space that molds to your lifestyle.
2017 Chevrolet Trax
Platform: Gamma II
Engine light - code p262b pending - 2014 Chevrolet Trax
Old Jul 26, 2019 | 5:09 PM
PastaMonster's Avatar
Default Engine light - code p262b pending - 2014 Chevrolet Trax
Any ideas on exact problem? new ecm required? Already pulled battery and checked all connections I could get to, made sure everything was clean
Old Dec 18, 2019 | 12:20 AM
Robert Olson's Avatar
Just because you have a code doesn't mean you have a active problem. Taking it in. Get the code deleted. Problem solved. If it comes back. Well you have a issue..
Old May 23, 2020 | 9:51 PM
You do realize that reading the code also gives me the ability to delete the code.
No need to take it anywhere, got a hoist right here, first action was to clear the code and run a few experiments but it keeps returning and is still running the same code. Discovered some corroded spark plugs and the need for a new ignition coil thanks to this problem... so double bonus, I suppose, car still running fine. New ECM came in and is sitting here and I suppose we'll get around to that eventually. Did disconnect the autostart in case there was some short or fault with the harness. Still no concrete answer other than putting in and programming a new computer. Which I just don't feel like... at the moment.
Old Feb 10, 2021 | 10:58 AM
To update on this, kept driving with it just fine and never did have any significant problems besides the check engine light-of-doom and code of pending failure. Finally got arouond to it and replaced the ECM this January 1st, reprogrammed, updated, had to reprogram clutch and windows... all is working well and car is driving more smoothly. I had auto-start, which we disconnected in case it caused a short anywhere. Running smooth with new ECM. Cost ended up being around $150 for the ECM and I dont recall what I paid for the subscription.
thomas caspary
Camaro
Jun 14, 2019 1:59 PM
Alemi1089
Cruze
Dec 27, 2016 1:47 PM
victoria_parker
2014 - 2018 (GMT-K2)
Sep 23, 2016 10:01 AM
pepecaido
Sep 22, 2015 7:13 AM
6in tahoe
Apr 18, 2010 10:40 PM
