tire pressure sensor 07 avalanche
dash started alerting me of tire pressure being low. i had air added and all tires checked. (used nitrogen) now every time i get in truck it is telling me to check tire pressure and says pressure is off on all 4 tires. would the nitrogen have something to with this or do think the sensor may be bad?
I have had 3 days and i'm aggravated!!!!!
kekerr75
Welcome to the forum... you might want to swing by a tire shop and have them read the battery status of your sensors.
Have your tires been rotated recently, is it possible they were not learned properly?
Official GM Rep
on
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> kekerr75,
I agree with the other posters, this may be related to the sensor. I also encourage you to have the vehicle inspected.
Please keep us posted.
Louis
GM Customer Service
![Big Grin](https://chevroletforum.com/forum/images/smilies/biggrin.gif)
Louis
GM Customer Service
Had the same problem with my 07 LTZ and what it ended up being was I had a tire pressure sensor go out and about 2 days later the other three went out I had to get them all replaced at the same time which i did (including labor) through the Chevy dealer and it ended up running me around $2,800 (this included an axle boot and the placement of it also) everything's good now though when I got tires replaced about 2 days later I ended up having the Les Schwab manager tell me that he could have with parts and labor replaced them for $350 or somewhere around there although they would not of course be original chevy parts... Oh yes and I also just afterwards had to replace my oil pressure sensor they all just went and tumbled one after the other
Dopeoperator
August 22nd, 2010 10:26 PM
