1995 G20 lower control arms
Where can I find lower control arms for my 1995 G20 van? They are no longer produced.
Can I use a G10 arm? Or an arm from a pick-up?
Chevy built the front end with C series front end parts, check the part numbers for ball joints, bushings, upper control arm assemblies all are the same for corresponding parts between C and G series. A simple research on rockauto.com and you can see the numbers match. The cross member, idler arm, pitman arm, and tie rod assemblies are different.
I have a link somewhere are cross over front parts from a van forum somewhere if I find it I will post. Here is a ink to Summit for lower control arms for C20 pickup. https://goo.gl/HXEzER here is listing for C10: https://goo.gl/cGXyFK
You can research if the C20 fits the G20. I do know that the C10 fits the G10. I just ordered a bunch of front end parts for my G10, all fit.
on
Rock Auto sometimes has a button for inter-species compatibility. But as a former parts guy(motorcycle), a part number is not exclusive to any model. Honda's parts numbering system tells you the model that the part was originally designed for, but it can show up anywhere, even a car part on a bike(or vice versa).
I got my 87 g30 upper / lower control arms from rockauto , much cheeper then advance / auto zone and in the ''info'' button it showed all models it fit. Mine is a bucket van and is 9500 lb.'s empty [the suspension and rear axle have been upgraded ]and i have had no troubles with them . I also added new springs from them at the same time. I hope this helps and good luck.
