Hub assembly on 1999 Silverado
I have installed 3 hubs and all have squealed ,the first two was cheaper ones ,so the third time I bought Moog and still squealing I put the axle nut to the specs I could find but they was all over the place form 156lb to 177lb .I need help please any idea how to solve this problem?
1 because service info says so
2 its a lock nut...the nut is oblong/eccentric in shape...not perfectly round...this locks the nut in place...after one use the nut will not retain the shape and could come loose...this nut tensions the bearing...if it comes loose, the bearing in the hub could be damaged.
