Site Feedback THIS SECTION IS FOR SITE RELATED ISSUES ONLY!! NO TECHNICAL QUESTIONS OR ANYTHING RELATED TO FIXING AN AUTOMOBILE
Hub assembly on 1999 Silverado
Old Oct 14, 2017 | 2:42 PM
kenmaze's Avatar
Default Hub assembly on 1999 Silverado
I have installed 3 hubs and all have squealed ,the first two was cheaper ones ,so the third time I bought Moog and still squealing I put the axle nut to the specs I could find but they was all over the place form 156lb to 177lb .I need help please any idea how to solve this problem?
Old Oct 15, 2017 | 11:30 AM
1999 new body style or 1999 old body style? engine ?
Old Oct 15, 2017 | 11:42 AM
kenmaze's Avatar
New body style,5.3
Old Oct 15, 2017 | 9:44 PM
mitchell service information says 177ft/lbs for torsion bar suspension 4wd vehicle. the nut is one time use...if you don't replace it; use blue loctite
Old Oct 16, 2017 | 6:01 AM
kenmaze's Avatar
Ok thank u ,so I would need axle nut and washer correct?
Old Oct 16, 2017 | 8:15 AM
if the washer is separate from the nut..it (the washer) is reusable.
Old Oct 16, 2017 | 8:34 AM
kenmaze's Avatar
Nut and washer are one unit
Old Oct 16, 2017 | 9:27 AM
kenmaze's Avatar
Just wondering why it's a one time use ,it a nut with a washer just don't make any sense to me ?
Old Oct 17, 2017 | 6:57 PM
1 because service info says so
2 its a lock nut...the nut is oblong/eccentric in shape...not perfectly round...this locks the nut in place...after one use the nut will not retain the shape and could come loose...this nut tensions the bearing...if it comes loose, the bearing in the hub could be damaged.
Old Oct 17, 2017 | 7:00 PM
kenmaze's Avatar
Thanks for the teaching tech 2 ,got new nut and washer . going to do the job Friday will keep u post on how it goes.thanks again
