Captiva The Captiva has been sold worldwide since 2006 and now comes to the US to replace the Saturn Vue
Chevy Captiva
Platform: Theta
HVAC not working
Old July 15th, 2018, 7:24 PM
Bowtie84's Avatar
Default HVAC not working
So, tried disconnecting the battery and leaving it for about 15min, reconnecting and that didn't help. I'm really hoping the stupid electronic actuator isn't kaput. Does anyone know how much a dealer charges to diagnose and swap them out? I tend to hate these kind of repairs as you tend to have to pull half the dash. But if it's like $500 I guess I'l suck it up and do it. I don't even know the part #'s though or if for sure that's the problem.
Seems a mix of cold and hot air blow from the floor vents and window defroster vent.
Captiva in question is a 2014 LT model btw.
Old July 15th, 2018, 8:56 PM
oilcanhenry's Avatar
500 to $700 dollars at a dealership.
Old July 21st, 2018, 6:57 AM
Bowtie84's Avatar
Any idea which actuator would cause this specific failure? Cost of part and or any documentation on replacing it?
Old July 21st, 2018, 7:57 AM
You say the HVAC is not working. Be more specific. Is it blowing hot air or nothing at all? Is the compressor kicking on? Are all the vents not working?
Old July 21st, 2018, 1:26 PM
Bowtie84's Avatar
Compressor is on and stays on, air comes though the defrost and floor vents only, air is not really cold once coolant comes up to temp as I'm pretty sure it's mixing the cold air from the A/C and hot air from the heater core. "It's like a snow man breathing on you" Cooler than ambient, but just barely. Yet the compressor is doing all it can, tons of water coming out the A/C condensation drain line. And like I said previously wont change to any other vents no matter how you adjust the settings.
Old July 21st, 2018, 1:42 PM
Sounds like you might have a problem with the blend door actuator and the mode actuator. Good Luck.
