Radiator fans
Old September 18th, 2018, 12:50 PM
Lizard85's Avatar
Default Radiator fans
Hello, my radiator fans wont turn off even after the vehicle is turned off. It drained my battery completely. I already changed the fan relays, temperature sensor, and the blower motor resistor. Not sure what else I need to do. Any suggestions?
Old September 18th, 2018, 2:50 PM
Do the fans run with the relay removed?
Old September 18th, 2018, 2:52 PM
Lizard85's Avatar
if I remove it it turns off.
Old September 18th, 2018, 3:42 PM
geo1's Avatar
I did some googling,water in the pcm connection,caused a few to do that,no parts needed, just a good drying and dielectric grease,hope that helps,I'm writing it down for another place to inspect
Old October 4th, 2018, 2:41 PM
Mgedling's Avatar
Default I’m having the same issue
Did you have any luck with solving the problem with your radiator cooling fans running with engine off ? I’m having the same issue and draining battery....looking for suggestions
Old October 4th, 2018, 2:59 PM
Lizard85's Avatar
No luck yet.
