Tahoe & SuburbanThe power, space, and brutal towing ability make the Tahoe and its longer sibling, the Suburban, arguably the best full size SUV's on the market today.
Have you burped the system.. you my have air lock in the heater core or in you block.. it's a must if you changed t-stat or water pump...
Check the two heater hoses going into the firewall in the engine compartment after driving 15 minutes; if not hot, see above, after confirming proper level of coolant.
If that's OK, strongly suspect a bad actuator under the dash, these control the air flow, like over the heater core or not. I had to replace one on my 2005 Yukon.
