Heater blows cold
Old Dec 18, 2018 | 3:43 PM
EasyReader68's Avatar
Newly Registered
Default Heater blows cold
2008 Chevrolet Tahoe LTZ A/C works well. Heater blows cold; it blows cold no matter how high the temperature is set. What could it be?
Old Dec 18, 2018 | 5:23 PM
kevinkpk's Avatar
What is the temp gauge showing?
Old Dec 19, 2018 | 8:40 AM
Cusser's Avatar
Originally Posted by Sonny B
Have you burped the system.. you my have air lock in the heater core or in you block.. it's a must if you changed t-stat or water pump...
Check the two heater hoses going into the firewall in the engine compartment after driving 15 minutes; if not hot, see above, after confirming proper level of coolant.
If that's OK, strongly suspect a bad actuator under the dash, these control the air flow, like over the heater core or not. I had to replace one on my 2005 Yukon.
