system running lean codes
so I recently had codes p0171 and 0174 pop up. I googled on how to diagnose but with the stats my burb is putting out I'm completely lost.
here is a pic of my stats. blue line=rpm green line=short term b1 and orange = short term b2.
any thoughts???
any thoughts???
I'm here for the party
my 02 would run ok at idle and cruising but if you tried to pass someone it didnt have no power and was running lean. checked pressure and it was only 23 psi. changed the pump and it went to the 55 psi that it should of been
nsisk01 (June 25th, 2019)
